The 800 series 5 tons have the Naturally Aspirated Cummins 250 in them....about 250 HP if you believe Cummins.
The M-818 Truck, Tractor has a towed load allowance of 37,500 lb.
818's are better suited to get a trailer to the hardball road and then let a road tractor get them to the final destination.
A M818 will pull a loaded grain trailer but it will not like it and it will be a slow trip........in muddy conditions it is somewhat better than a rear wheel only tractor but you can get them stuck...and they have a sprag transfer case...the rear wheels have to be spinning to engage the front axle...sometimes too late if you are in a bad spot.
There may also be issues with having enough air to the brakes and using the lights on a commercial trailer.
There are several members on here that are using the M915's to pull grain trailers and are having good performance with them.
I have sold two M915's to a guy that uses them for all types of farm related hauling and he loves them.
The M915 or M916 (has all wheel drive) would be my choice for a line haul tractor.
