1ton cucv k5 turbo
- 0
- 18
- Castalian Springs, TN
While your under there turning wrenches, i would also change out the motor mounts, if your trans mount was "mush", that could be the reason for the cracked housing....
Hey John, with that said, what year cores are better to build off of or can any 700 be upgraded? I know I have one with a 1983 case but it has 30 SP input so someone has fooled with it. Other than the "K" case, are there any internal case differences?no, 700's are so easily available I'd not keep it. I've got 10 of them in my shop that are going to the scrapper on my next trip.
Actually, the cable wasn't as bad as you would think...without the transfer case and front drive shaft in the way, I was able to reach up in there with both hands and hook it up pretty easily. I say the front drive shaft wasn't in the way because I forgot to put it on top of the cross member when I put it back on yesterday . So, I had to undo 4 nuts and pop the front drive shaft off, lift it up over the cross member and reattach the front yolk. Putting the TV bracket on was a snap. I did have to undo the temp sensor because the bracket wouldn't fit over it, no biggie.Is your TV cable connected to the transmission? Getting the cable connected to the TV linkage while the trans is up in place might not be much fun.
I guess the document was put out by TCI, but it has everything you wanted to know about the adjustment.I would likee to see that GM PDF Tom.
This isn't Westy we're talking about here!!!gimpyrobb said:what a junker.
-water in fuel lightCan someone tell me why there are 3 wire connectors on the OEM fuel filter?
