- 14,213
- 1,611
- Dayton, OH
When I was under the truck last weekend putting the adapter plate on the bellhousing I was picking off Haspin mud from 2011.
Has every body updated their locations on the map? I will make it easier to send reminders for haspin in the spring.
I have a hard time getting to sleep in the 900 degree weather. I also fear drowning in my own sweat.Sleep in the back of your CUCV. I'm sure someone can cook up some chili-mac for you.
Also makes it easier if people want to Convoy together to Haspin. They can see who is around and make plans.Why? What would the cutoff be? 50, 100 or 500 miles? We have had members from all over the place and it would be difficult to catch everyone with a PM. This year at GASSR we had two from different continents. If they aren't reading the site and see the thread when Stretch posts it up then they most likely won't see a PM either.
Um, don't you live in FL?I have a hard time getting to sleep in the 900 degree weather. I also fear drowning in my own sweat.
I have a 3 ton portable air conditioner I can put in front of you. Just pitch in for diesel.I have a hard time getting to sleep in the 900 degree weather. I also fear drowning in my own sweat.
Fred, will you be using your smoke-screen when you roll into haspin?the 13th sounds good to me i want to see more trails than i did for the fall rally, if me and Augiedoggy can get togather befor then and do some trading i should have my M35A2 Tractor Conversion done by then.... ATTN to all members you will not know its me when i roll up to the next rally, this is a top secret build and there might be a thread started with pic's. But, i may need some parts off some of you if you have what i need. The LDT-465-1C will be modified as well. When i'm done with the engine it will be able to withstand 30 PSI of boost and no the engine will not grenade. I cant give out all my secrets now but if you show up to the next haspin rally ill show you and tell you.
Thanks Rob, I'm figuring on using a lift to remove and switch the bed, and we have a forklift available at my work if needed.Of you need a forklift let me know. Makes it alot easier to get the bed and 5th wheel off.
