Tubeless... A ton and a half of stop leak i would think, Like a gallon? at least? And i doubt it would work on the rubber O ring,just a guess , but I think it takes motion for it to work and that would spray it on the outer walls where leak problems would occur that they were designed to stop, And the O ring is in side. And since the mil and contractors with bigger tires dont use that stuff that I ever heard of , there well may be a reason... but hey if someone wants to pump that much in there and try it , I am sure we would like to know
I will take a guess at this too, i think it might "hurt" the wallet of buying that much slime, and then driving the tire low, and if it does not work will ruin the tires side wall as we know they are prone to damage when to low on air, Just giving cons I can think of from your pros, ...
