JOECOOL48
- 0
- 16
- Fitzgerald, GA
I saw a post just the other day about a SS member having his wiring cut and vehicle vandalized. The thread continued to the discussion of battery disconnects. My Deuce runs on 2 12 volt batteries in series, so I used a Harbor battery disconnect between the two batteries.
While doing that I also ran 12 volt outlets to the back side of the right rear mudflap(for use with an electric hoist) and behind the cab on the drivers side. Each outlet has a waterproof box with a cigarette type power point plug and a positive and negative stainless bolt to clamp devices that might use alligator clips. I also placed several power points in the cab to charge cell phones , power radios and the likes.. I also replaced the air tank drain valves with in-cab spring operated valves. At $5.75(from eBay) each I figured I would give them a try. At my age rolling around on the ground and getting up and down is not as easy as it used to be. I will let y'all know how they work.
