M915 vs M916
lakeydna
Devon, AB
Does anybody know where the height difference comes from between the two trucks besides the tires and having a front diff. The M916 sits higher when looking at the front bumper, is it double framed? I would like to get a M916 but I think I might just put a transfer case and front diff in a M915. Any advice/tips?
wreckerman893
Possum Connoisseur
15,626
2,039
The M916 has 24 inch tires and heavier springs which makes it sit higher......it is also designed for fording and is higher for that reason. The M915 is basically a day cab, line haul truck for mostly highway driving. When I was in a unit at Fort Benning that had M916's I could never figure out why we had crappy city tires on them instead of lugged tires that would pull in the mud. With a dozer on the lowboy that thing would get stuck in it's own shadow.
quickfarms
24
Orange Junction, CA
Standard street tractors have a drop front axle. The driven front axle is a straight axle and make the truck sit a lot higher. The light duty driven front axles have an offset differential. The heavy duty driven front axles have a centered differential. With a centered differential the truck must sit a lot higher for the front axle to clear the engine and transmission. The rear can be handled with suspension modifications, a sub frame or z brackets in the frame.
JH1
Seattle, WA
Another factor in choosing a collector vehicle like this is the turning radius. I have a M915 and curb to curb turning diameter is 53' vs about 80' for the all weel drive 916 and above. For getting around on city streets and backing around, I appreciate the extra 'dexterity', if such a word applies to these things.
lakeydna
Devon, AB
The M915 seems more like a practical truck, better road speed, handling and such like a normal OTR tractor but the M916 just has that mean stance and would be a cooler truck to drive. Besides I don't think the word practical goes along with this obsession of MV. Could you change a M915 into a M916?
73m819
319
gainesville, ga.
It would be easier to make a 916 into a 915.
What I would like to do is drop the front axle and transfer case from a m916 and install a non powered front axle and maybe a aux. transmission, this would make a NICE winch equiped recovery tractor
lakeydna
Devon, AB
I've already got four, a pair of A1's and a pair of A2's. I want the rear winch and higher payload. I'm in the hunt right now for a M916 and am jumping through hoops trying to get an EUC.
Debest
Carolina/PR
Thanks for the info
