bimota
- 3
- 0
- Campbell, CA
M944A1 conversion nearing work ready status
Ok, we are up and making equipment. Joe is running the lathe off a MEP-003 and the truck generator also works. The truck remains hard to start - so any advice on using the ether kit is appreciated. We also are looking for the Manual for the Southbend 1308 lathe. We found the lathe drained of all fluids - risky since we did not check till after starting the run. Special hydraulic oil Shell Trellus 27 is called for - not hard to find but special blend. Check those fluid.
