Reinstalled the lift pump. Replaced the hoses. Added 10 more gallons of diesel fuel. Fuel pressure is over 5psi now cranking. Stays up there as well. Pulled the center HH plug, great fuel flow there.
Couldn't get it to start at all. No smoke from the exhaust. A whiff of starting fluid and WOT it fired right up. Idled great. Fuel pressure was at 30-35psi. Revved ok as well. Gave it WOT, stumbled, shut off. Would not restart. 5-7psi cranking.
Got my son to jump back in and hit the start button while I whiffed it again. It stumbled for a bit, finally cleared up with a lot of whiffing. I didn't touch it. Idled at 800rpm. No wandering or stumbling. 30-35psi of fuel pressure. It idled no problem for 5 minutes. I stayed around it this time. I heard a ever so slight stumble. Then 2-3 seconds later it shut completely off like as though someone pulled the engine stop.
I've given up for the day.
I'm baffled at this point. I've chased so many things, I'm not sure what to try next. The fact that it will idle and rev great at times makes me think the HH functions correctly. As well as the booster pump. But the fact that it acts at start up like there's no fuel, and if I WOT it, it will stumble and die, makes me think it's the governer. The cutoff linkage moves completely free. It's at the 7 O'clock position. I haven't pulled it out of the pump yet though. But I know the cutoff is just like the ambac IP I dealt with on my generator. If it moves, it should function. Unless that little wedge is broken maybe? But that still wouldn't account for the perfect idle/running at times.
I could try swapping fuel filters again, but seeing the flow and pressures I'm getting I don't think that's the issue. I could try replacing all the nylon tubing as well. But after that, the only thing I could try is replacing the HH?
