Wncenergy
- 0
- 0
- Weaverville nc
Thank you again to everyone here. I am about to go attempt to test glow plugs and hook up the freshly charged batteries. The Relay had too many wires going to it and Doghead pointed me in the right direction in removing the wrong ones. The first picture shows the toggle switch that I have to manually hold up for the glow plugs. The OFF wire was wired to the top bolt on the relay and split off as shown in pic 2 and ran into the cigarette lighter in pic3 then out and cut bare as shown. The rest of the wires in pic2 are for the cd player which was powered from the relay on the top front bolt on the relay. The wire that is in the ON position on the toggle switch runs straight to the lower front bolt on the relay.
I took the OFF wire from the toggle and removed it from the top bolt from the relay and grounded it as shown in the pic5. I removed the wire from the front top bolt for the cd player entirely. I left the ON wire from the toggle switch to the front bottom bolt on the relay alone.
Now I will go check the gp's. I checked half of them yesterday by setting my multimeter to 20k ohms, I first tested to make sure I was getting zero and then touching one terminal to all parts of the glowplug and the other right next to it to the engine block and didn't even register a reading. I am guessing that is a good sign right? Then I will start to put everything back together.
