Tplane37
- 0
- 0
- Dallas, Texas
If you are going to do a two speed set up on the transfer case, you will have to do one of two things: (1) put an auxiliary gear box between the transmission and the transfer case that will give you the gearing options you are after. Or, (2) Find a way to put a typical type reverse cut ring and pinion in the front axle and put your two speed transfer case in.Hi, I am a new member, not sure if your still looking at the mods for your truck. Anyway I have a 1955 M135, I got a 1991 GMC school bus with a 366BBC and an Allison 4spd automatic tranny. I transfered the engine, tranny, all the front end/dash wiring, power steering, power brake master cylinder, added propane tank and two turbo chargers. I now have about 450 lb-ft of torque and around 350 HP at 10lbs boost, according to turbo chart. I left the stock transferr case, and single speed also.. Anyway it works very well, i use it for hauling wood, water and landscaping stuff. I would like to convert the transferr case to a two speed but not sure how this is done. I have another same M135 and a 7.3lt powerstroke of which I want to install. The allison auto tranny and any engine will work, just would be nice to have low range in the tranfer case for those over weight had wood days...
If you are going to go through the trouble and expense, you are probably best to put something like a Gear Vendor Overdrive/Underdrive between the transmission and the transfer case as option (1) would imply. The reasoning is that many have searched for suitable gearing options on these axles with less than satisfactory results, and the transfer cases on these truck are uniquely setup to reverse the direction of the rotation of the front drive shaft to allow the ring and pinions to be interchanged between either rear differential or the front differential (in other words, all three axles have the same ring and pinion, not just the same ratios). Also, the transfer case also functions as a reduction box using a ratio of 1.16:1, unlike a normal 4x4 that uses a 1:1 ratio for high range.
