nanlin
- -6
- 6
- Sacramento, CA
Thanks HarleyHouse!! That looks great!!
Can you still tow up to the 4200lb spec with those tires?
Doing the math in my head, which is notoriously dangerous, it appears that you're saying your receiver is only 9" off the deck? That doesn't sound right.Thanks Chevimp63!! Looks like getting smaller wheels is the way to go.
Thanks Mainsail!! I thought about getting a custom riser. The max prefab is 12in right now,
I will need about 20 inches. Just concerned that it is too high to create large stress on the
bend if trailer jerks? Of course, I guess I can always bulk up the rise with bulky diagonal
support...
Do you have a thread on this process some where?Cut the hitch and weld on an adjustible channel.
Yes they can, and if you have a bad back, put some weight in it back of the tires. That will make the tongue even lighter.Can these trailers be easily moved by hand on level concrete, as in a shed?
What did you use?I know my m101a2 is much easier to move, since I put a wheel on the front. The landing leg sucks.
