steelandcanvas
- 85
- 48
- Southwestern Idaho
Here's what I have:
http://www.hewittindustries.com/Pyrometer%20Gauges/pyrometers_2_inches/010-213-XX-X%20C%20Pyrometer%200-1600F%20REV%20C.pdf
I drilled and tapped a hole in the manifold right above the turbo. They have different lengths of sensor wires. Hope this helps you Ron.
The Hewitt site is under revision so the Boost Gauge descriptions were not available. It is a 2" face, black background, 0-15 PSI boost, w/red led lighting (24V). The 0-15 PSI gauge has the greatest needle swing for better accuracy. It comes close to resembling the stock Deuce gauges. If you order from Hewitt, call them as they were very helpful with my purchase.
