svd dragunov
- 0
- 0
- grants new mexico
anyone tried it? would it work? is it safe? more of a curiosity have not tried it.
Next time you have to poop, just take a deuce on your deuce doghead.I wonder if you could use dog crap as wax. It's free.
hmm thought it was obvious i was talking about WMO thinner, considering this is the alt fuel section.You should use what is recommended on the can of paint.
let us know how that works out.I wonder if you could use dog crap as wax. It's free.
Ray you must have not had enough coffee this morning , everything that comes out of the exhaust stack except water is a poison gas.Then Would these chemicals make posion gas coming out of the exaust stack???
If you'll read the article I posted, the chemicals in brake cleaner can break down into hydrogen chlorine and phosgene gasses.Then Would these chemicals make posion gas coming out of the exaust stack???
LOL....nevermindRay you must have not had enough coffee this morning , everything that comes out of the exhaust stack except water is a poison gas.
yeah gasoline kinda has the same effect, and yet people still use that to thin out wmo. im not saying im going to try it, was more of a curiosity.We've all had a can to spray on a dirty part that was globbed with grease and oil right !
Carb Cleaner as well if you were out of brake cleaner.
When you sprayed in on that oily part - what did it do ? It breaks down the grease and oil chemical base
to where you can just wipe the part clean and almost lick it - becuase it cleaned it so well.
Now take using this in WMO - why put a chemical in there to break down the oils and run it in your fuel ???
Diesel engines - yeah - go ahead and grab that can of starting fluid - it as well breaks down oil - oil is what is lubing
your cylinder walls in your engine right ?? Spray starting fluid to start - wipe oil out of your cylinder wall just to
fire up your engine - makes a lot of sence to me as well. If you spray to much and it fires - ever see a Cummins engine
piston rod bent because of it.
Tell me how that thinner works out for ya.opcorn:
To be fair it does say when heated and mixed with argon.If you'll read the article I posted, the chemicals in brake cleaner can break down into hydrogen chlorine and phosgene gasses.
1% of the air you're breathing in is argon.To be fair it does say when heated and mixed with argon.
Yes, but it does not only form hydrogen chloride gas (HCL), which is poisonous, but even worse, burning it also produces dioxins, which are known as "super toxins" in academic literature. However, the concentrations are no sufficient to pose a health hazard to the operator or the public driving behind a diesel engine that is powered by a fuel blend containing braklean/TCE at concentrations at or below 5%.Then Would these chemicals make posion gas coming out of the exaust stack???
Gasoline, and other solvents, do not "break down" oil.The dissolve it by thinning, so it is gasoline, and other light solvents are very effective solvent for thinning waste oils into diesel fuel. Gasoline also comes from the same place that motor oil comes from, crude oil. Blending them together into a fuel blend is just putting them back together.yeah gasoline kinda has the same effect, and yet people still use that to thin out wmo. im not saying im going to try it, was more of a curiosity.
