SouthernSteel
- 7
- 18
- Jacksonville North Carolina
Well everyone any ideas,First let me tell ya what i have done to the 1986 Army M1008 (Aka Jolly Green Giant).Mind you this truck has been sitting up for over a year just to give a heads up.Truck Cranks but will not stay running and when i first cranked it up LOTS OF WHITE SMOKE Prior owner did a really weird concoction of who knows what so i drained the tank,however when i first cranked it it was with the original filter so im sure what ever was in the filter was what caused some of the white smoke,It high reved and then died.only thing it does now is crank and shut off.
#1 (2) Good batteries (fully charged)
#2 (1) Brand NEW GEAR REDUCTION STARTER(2 new Starter bolts 15544950 and new gear reduction starter bracket 23502257
#3 (1) Doghead Relay Conversion (currently works great )
#4 (1) Eight Brand New 60G Glow plugs and Gp solenoid ( all work )
#5 (1) Done away with GP Resistor on the firewall (no longer in the Loop) Did 12v Conversion (i know they are already 12 volt) It works though :]
#6 (1) Drained tank of old fuel added 7 gallons of new diesel
#7 (1) Changed Fuel Filter and oil filter and did an oil change.
#8 (1) Removed Dash cluster replaced all bulbs and cleaned all connections.(Currently No issues with dash lights Gen 1 and Gen 2 lights all work)
With that being said truck cranks but will not stay running unless i keep my foot on the accelerator pedal,i read the TM's and i didnt see anything really pertaining to the situation so any insight. Per the tm's i saw to test the red wire at the Ip pump and i was getting about 10 Volts the high rev(cold solenoid was getting 12volts) Thanks everyone.:]
