- 14,251
- 1,702
- Dayton, OH
Notify the EPA that your place is now a Superfund Cleanup Site.......
You lost me. [RD] Procedures: You should have the tank removed with the lacquer thinner doing its thing. Then you'll dump this into a bucket and rinse out the tank with a garden hose. You then rinse with muriatic acid to dissolve rust if needed. If the lacquer thinner and acid hasn't done you in yet, you can then rinse out the tank with acetone to help remove any water residue.
John
Tried that a three or four times. Here is what I see:What happened to the WIKI? It has all the battery info.
Jerry
I ordered 2 oil so I have a spare. I plan to run it a little bit and then change it again.I think you have it the wrong way around, there should be 1 fuel water separator, then 2 fuel filters, plus 1 oil filter. The air filter will likely last for the life of the unit, they are oversized designed for extreme dust conditions, etc.
Ike
