rsh4364
- 15
- 38
- greensprings ,ohio
thankyou, but ouch ! Ihave 2 vehicles that take these lights...
Relay upgrade.Well i installed the new lights today, went in easier than i thought. Thanks to the TM i actually read how to do it first. There still really dim so i think i gota look elsewhere for my problem. Where should i start? The high beams dont look bad but the low beams are barely even visible even with the new halogen 55/60 bulbs. Think i should get the new wiring harness from LMC truck or look for some bad wires somewhere. This is pretty frustrating.
Is that the LMC truck harness or something different? Got a part #. Thanks, im pretty bad with electrical stuff. If it doesnt have a on/off switch its usually past my comprehension.Relay upgrade.
The lights came assembled, with the mounting bracket and the bolts. its on the web site."I drilled holes in the grill"
I assume theyre stud mount lights then? What part number, i was under the impression they were the m35 replacement lights
Best price on short search is 223 each
Use relay to switch headlights on/off. provides clean ground, larger wire for less voltage drop, and removes load from switches (no burned out switches).Is that the LMC truck harness or something different? Got a part #. Thanks, im pretty bad with electrical stuff. If it doesnt have a on/off switch its usually past my comprehension.
We're getting the Truck-Lite LED head lights and the Truck-Lite Auxiliary LED spot lights mixed in with this blog about headlights. I included a picture of my truck with both installed. The info for the spot lights can be found here: http://www.truck-lite.com/wcsstore/tl/resources/images/en_US/pdf/7InchAuxSpotNP.pdf"I drilled holes in the grill"
I assume they're stud mount lights then? What part number, i was under the impression they were the m35 replacement lights
I like the idea of replaceable bulbs. Are these similar in brightness to the silverstars?I went with hellas#003427291 from Summit ,because you can replace bulbs not the whole assembly,takes HB-2 bulbs,I also did the harness upgrade from lmc trucks,huge improvement..was gonna do silverstars but noticed 150hr. life and went with hellas,because of replaceable bulbs,silverstar also makes a HB-2 bulb...
great brightness.longer life than silver stars.I like the idea of replaceable bulbs. Are these similar in brightness to the silverstars?
techno, I want to know how these lights are working for you, I like the look. how much and where do you get them?
As far as headlights, I'm getting a pair of 55W HIDs in a blacked out projector housing... Less than $100.
DO get 4300k, DO NOT get anything above 5000k. It turns blue, and you have nothing but glare, and the inability to see in inclement weather.
