- 18,540
- 5,835
I'm looking for a SOURCE (Manufacturer preferred) from which to obtain HEAT SHRINK Wire Bundle Insulation or Wrapping "Tape" that could be LOW TEMP "shrunk" around irregular shaped objects to provide containment and/or protection from low pressure fluid seepage.
- The LOW TEMP requirement is a high value factor in product selection.
- TUBE forms could be used in smaller applications - 4"-6"max. diameters (would actually be irregular profiles, not true circular cross-sections).
- WRAP material (think: SARAN WRAP) with self-bonding, LOW TEMP heat contraction properties would be used for cross-sections greater than any available TUBING would accomodate.
I am posting this in the ELECTRICAL Forum since I have prior experience with similar material from back in my "aviation days" when I worked in avionics/electrical design for Mitsubishi Aircraft International (1979-1986), but have long since discarded all of my reference material and notes.
THANK YOU!
THANK YOU!
