Rambling Wreck
- 5
- 18
- Woodstock, GA
When you get a chance, please list the total length of the truck.
Okay why put them on? Are you going to make some kind of storage on them or just looks?Update, I Also installed the tray back over the Passenger-side fuel tank. Still need to get to the drive-side... only some much time in a day.
Both and all the above.. I wanted to protect the fuel lines/vents on the top of the tank, they make a good step to go from the cab to the bed, they allow a good spot to add tools/boxes/Fuel-Water Jerry Cans between bed and cab/ect. and I like the way they look...Okay why put them on? Are you going to make some kind of storage on them or just looks?
I think I am going to keep both trucks, Remove the box from the M934 and put it on a gooseneck trailer. then turning the M934 truck into a long wheel base Tractor with sleeper or S-250 shelter behind the cab. Using the Trailer for storage now, but maybe a Man Cave/Travel trailer... How is yours coming Agazza2?Glad to see you have your trailer back home. Your EUC cleared quickly too. Maybe now you should keep both trucks, so you have one to pull the trailer with Or is it going to be used for storage of all the military items you collect?
Great, I think you find it useful to have the second truck with a fifth wheel. I will start on my trailer/TV conversion on Sunday. Saturday I will bring the M931 to the Burnet Airshow for display along with others from the Lonestar chapter of the MVPA. I will start a thread when I start. Slot of inspiration from Rayzers build of his M146I think I am going to keep both trucks, Remove the box from the M934 and put it on a gooseneck trailer. then turning the M934 truck into a long wheel base Tractor with sleeper or S-250 shelter behind the cab. Using the Trailer for storage now, but maybe a Man Cave/Travel trailer... How is yours coming Agazza2?
I wanted the extra fuel tank to fit between the tire rack and cab and still allow for using the bed rails bows and cover... If I was not using the extra Fuel Tank I would of left it further forward..Truck looks great,what was the reason you had to move the bed back 4" from were you originally had the bed. Thanks
Not at all, I'm not sure I ever had an idea of my own, mostly robbed from other SS members... I didn't even ask if they mindedI will do mine the same way a 932A1. I like it and thanks for the info and pics. Hope you don't mine a repo of yours.
