twomorestrokes
- 10
- 18
- Charlotte, MI
Yes. I worked in Engineering at Air Lift company for years and used my 2500HD as a test mule. It had about every rear suspension imaginable on it from stock with steel helper springs (the worst) to full air suspension using rolling lobe air springs. The heavy leaf pack of the M1008's may get away without many issues using blocks, but the exceptionally weak 2500HD factory spring packs allowed annoying axle wrap under adverse conditions which is never fun. Adding blocks worsens the effects of axle wrap up.Have you ever experienced issues with blocks?
