7" Receiver Riser Question
kjo43
Upstate, NY
I just bought a M101A2 -> More on that later once its in hand :)
Need a little help from those who have one of these 7" risers, maybe grab me a quick measurement from center of receiver to center of pintle?
I need an effective 5" net rise from the center of my receiver to get to 25"... The question I'm trying to answer is will a 7" riser plate (like this) using the highest setting get me enough height using the top 4 mounting holes? I don't want to buy the 12" riser for a number of reasons.
Thanks!
doghead
4 Star General /Moderator
1,174
Well, if the vertical bolt spacing is 1.75", then the top set of holes should mount the pintle hitch 5.25" higher.
kjo43
Upstate, NY
Well, if the verticle bolt spacing is 1.75", then the top set of holes should mount the pintle hitch 5.25" higher.
Yes, you are right on - there's 5.25" of adjustment in 3 choices (top, middle or bottom). but Bottom may actually place the lunette resting point lower than the center of the receiver, I cannot tell this without having both the riser and pintle together.
kjo43
Upstate, NY
And the answer is....
Drumroll please.......
The 7 1/2" riser + pintle in the top holes, gets you an effective lunette height 2.5-3" higher than the center of your receiver.
Thanks to all those who played.
