Jeep Nasty
- 245
- 43
- NH
After searching several threads I don't think this particular problem has been covered. The brakes work fine I just have to keep an eye on the fluid levels. I have a slight leak after use, coming from the under the boot from the main shaft that attaches to the brake pedal under the body. I found a thread from g503 that talks about some .97 cent O-rings that you can replace as a rebuild for these pricey master cylinders on the A3's. I wondering if anyone who is more familiar with master cylinders could advise on whether this fix may address my problem. They also talk about honing the cylinder and I' not sure what that entails.
if this wont work, does anyone have a line on an affordable master cylinder for this thing?
g503 thread is here. http://g503.com/forums/viewtopic.php?f=26&t=177512#p1115594
