FireFighterHill
Banned
- 1,540
- 62
- 0
- Riyadh, Saudi Arabia
2 in parallel and 2 in series it is then!
Going to cover it with a piece of sheet metal or a dummy slave recipitical and put a dunce cap decal above it. What you think?Sometimes my M923 starts right up, sometimes it don't. I plug it in to a 24v jumper and it fires. I guess one or more of the original batteries are toast. I think I'm gonna do the two batteries in the side box trick. Have the batteries. Also have several adjustable hummer buckets and a 12v center console made out of an ammo can. Whatcha gonna put in that old slave hole?
On the starts and no starts, on my GMC Duramax that means I have a bad battery!Sometimes my M923 starts right up, sometimes it don't. I plug it in to a 24v jumper and it fires. I guess one or more of the original batteries are toast. I think I'm gonna do the two batteries in the side box trick. Have the batteries. Also have several adjustable hummer buckets and a 12v center console made out of an ammo can. Whatcha gonna put in that old slave hole?
Don't do facebook!!!!Like It! bigboy44. Oh, this isn't Facebook.
I drove the truck about 75 miles with no issues to the hot hand glove protectors. I too have had fingers in the gloves srivvel up due to the heat from 1/4 inch jet rods and goughing rods.Those "hot hands" are for use when welding with Flux Cored wire which runs HOT. I've smoked up gloves doing multi-pass welds on beams and after cooking my hand a few times I tried the hot hands and the worked really well. I don't know what their rating is but they can take some serious heat, so they should work well protecting those cables.
