rizzo
- 8
- 38
- Port Huron, MI
Where is the best place to purchase parts for the stock military distributor ?
Rotor cap condsor points ballast resistorNormal things like points can be had from NAPA. What are you looking for?
There seems to be a large gap between the cap and rotor. It quit on me while running last fall. I'm going to readjust the points but want to check the other parts. I'm Leary about the gap between cap and rotor.[/QUOTE]
If the rotor to cap gap opened, a chance the bushing/thrust washer that keeps the shaft in place in the stem DIED, allowing the shaft to drop a bit, does not take much to open the air gap enough to loose spark or at least make things bad enough that spark is so weak it might as well be none.
just called the number TODAY and its been disconnected, did they go out of business?Winers in Akron OH and Antelope Valley still have a lot of gasser parts.
They're still around, I called them last week about some torque rod ends. Google Sam Winer, that's where I got the number.just called the number TODAY and its been disconnected, did they go out of business?
