2013 Haspin Rally Parts Thread
212sparky
Monroe/ Ohio
I have a power distribution box that has a similar connector. If I can get some pictures and numbers I will see what I can find for you.
jdknech
Jeffersonville, Indiana
Do you know what kind of connection you are going to use on the other end? 50 amp range plug?
I cant find any markings on the trailer plug.. but i would guess it to be 100+ amp.. it is about 4" across... we pulled the plug for Matt's s280 over and it was much too small.. (it looked the same..) matt is supposed to be snapping some pics of it and sending them to me.. i will post them when he does.. thanks- Josh
2002ford
dayton,oh
I have a couple 2009 m1101 trailers I need to get rid of. They have 265/75/16 tires instead of the humve tires. Anyone interested?
Ialso have a clean m1009 if I get the tranny fixed by then.
271
10
SW Ohio
There are a few things I could use if anyone has these around. All of these are for a M35A2.
1. Two wheels. No tires needed as I have two new tires to mount. I just need a couple of wheels but if you have good wheels with trashed tires, that would work as well.
2. Two 1100x20 inner tubes.
3. A cargo cover. Green would be best but camo would be fine. I could use a few bows as well.
Thanks to all for your help.
Dave
eagle4g63
34
North/west Indiana
Kenny would be my first choice. I haven't been up his way to get one. This could change soon.
Thanks for the tube info.
If you get a hold of Kenny and work out the top, either Gungearz or myself can make sure to get it to Haspin for you.......gungearz drives by his place all the time for work......and me, well......I'm the one going to be hauling all our parts!!! Just let one of us know.
FarmerRob
Chandler, TX
Just wondering if anybody would be interested in some Deuce parts for the rally, since gungearz and eagle4g63 have graciously volunteered to truck them down there for me.[thumbzup]
Transmission
Hood
Battery Hold-down Brackets
Complete bobber kit minus u-bolts
Outer windshield frame
Low-mount side mirror
Electronic strobe convoy lights (non-rotating)
LED marker/clearance lights
Rear axle
I'm sure there's more but I can't think of it right now.
Also have available a complete M35A2 winch truck with heater and a complete M105
PM me to discuss prices and payment, please.
Thanks.
swbradley1
Modertator
1,602
Dayton, OH
i haven't heared anything about fuel... i am under the inpression that its a "bring your own fuel" type thing... i will be there with a 150gl of extra fuel, but that is to play for the week, and get home on...
The one year I got to bring a truck I doubt I used 5 gallons of fuel the whole time. I drove over with a 105, played and then drove back and never got fuel. 150 gallons is overkill unless you are pouring on the ground to mark you trail. ;-)
jdknech
with the 5ton, when i go 4wheeling (mudding) i used 25-30gl a day.. (i work the truck pretty hard) plus pulling the M971 trailer home at 20K LB, it tends to drink the fuel... I dont plan to use 150gl, but I want to be prepared.. hopefully your right though :wink:
