- 14,619
- 4,740
- Buchanan, GA
Be careful with the cans. They can kill.Is the spring brake diaphragm supposed to be field replaceable? Yes, I read the TM. It shows how to take the whole assembly off then just says " Check spring brake diaphragm for leaks". If there are details on replacing the spring brake diaphragm could you point the location in the TM for me? You just can't straight in present the can straight in to the housing. The pop off safety ears on the can requires that the can be twisted on wrinkling the diaphragm. I am going to try to lubricate the diaphragm with dish soap and/or lay hack saw blades flat on the diaphragm to slide the can over the diaphragm while twisting. BTW I am having trouble with the text editor. I can do CR's and after triple checking the text comes out all screwed up after publishing. I even compose in my word processor do a spell and grammar check cut and past and it still comes out screwed up.
If you're using IE 10, try setting it to compatibility mode.
