Fuzzy66
- 0
- 0
- Delaplane, VA
No, the Plains Service Center.Does he work at Advance Auto?
It is required in Va if you're not going the antique route. Both of my M151A2s needed them (I put regular tags on 'em instead of antique).THe duece is titled as a 1997 and my stepson (a state inspector) says a light may be required. So I'm not sure about the requirements. Anything you know would be appreciated.
Thanks very much. It's on order.Fuzzy66 check out Eriks military they have a license plate light w/harness part# x-6076.
Negative. He runs an automotive fabrication shop. Does, tube work, drag chassis, anything fabrication related, jack of all trades but specializing in 4x4s. Does sinister good work. Full Awn Fabrication is the name of the operation. He doesn't advertise much because he brings in all his work word of-mouth and its just enough to keep him busy and not in over his head.Does he work at Advance Auto?
I'm in Harrisonburg whereabouts are you located?Hey y'all,
New guy down in the Shenandoah Valley - currently looking for a M35A2 w/w. Glad to see VA has an active MV group.
HopefullyAnd how many of you will be at the VA Rally in September?
