MajorGasAttak
- 1
- 1
- West Milford, NJ
What is or should be used to drop out the starter solenoid once the generator is running? On my MEP-003a someone added an additional oil pressure switch plumbed in line with the oil pressure gauge. While it all works fine there are times when the generator may be cold and during cranking the oil pressure comes up enough to open this second oil pressure switch which then knocks out the starter solenoid before the engine fires up. One wire from this switch comes from the control box and the other goes right to the solenoid. I can get the wire number and pictures if needed.
Thanks
Thanks
