German 5ton owner
- 0
- 1
- Germany/ Ludwigsfelde
My Truck has brake problems and i dont know how to get this solved. 2 weeks ago i parked my truck for a paint job. After that i drove it out and the brakes applied full. The truck didnt move at all.
I thought this could only be the Hydrovac. thats why i changed the hydrovac and bleed the hole brake system.
After that i started the truck again. First the brakes worked but after reaching full air pressure the brakes applied completely again. All 6 wheelbrakes are applied. The brake only releases if i open the drain valve under the air pressure tanks.
The service side glad hand is ok and it vents.
What could be the reason for this porblems?
Did anyone ever had a problem like this?
