Datajockeys
- 1
- 3
- Madison, AL
This is so frustrating. Almost done with the rebuild and I can't find the e-brake parts I need to button my rebuild. Can you assist?
1) E-Brake hand lever assy. - Someone overtightened the hand-lever adjustment knob, fused the adjuster and cut off the protruding threads. The top cap is missing as well.
2) E-Brake cable for the M416-A1 - Not sure if the Army or the Forest Service replaced the OEM axle with one form an A1. The OEM was too long and parts were rusted off.
3) Brake Cable Shield Mounts - The are bolted under the frame to keep the cable shield in place.
This is a good opportunity for someone, that has replaced the braking system or axle, to make some money.
