Bought this truck a week or so ago and its had this issue since i bought it.
Crank crank crank in the morning trying to get it started, After its been started it starts up right away. Till it sits overnight.
thinking it was glowplugs i replaced them with ac delco 60gs. Still same problem.
when cranking white exhaust comes out so its getting fuel.
Also when turned to the on position i hear a clunk when the WTS light comes on, but no other clicks after that so i dont think the plugs are cycling.
- Hoping you guys could help me out as its really annoying.
Stationed away from home and of course my multimeter so i cant do any readings.
Tomorrow when the engine is cold i will pull a plug and visual check. but i cant hear them cycling, nor does the volt meter in the dash reflect this. Constant reading
