bp m1009
- 0
- 16
- Somerset County NJ/ NE PA
Ok so my 1009 has a lot of positive camber, so I decided to document the fix in case anyone else wants to do the same. Lots of people dont know that camber is adjustable on a solid front axle.
Tried to get some pics to show how positive my camber was, it was wearing the tires bad and causing cupping. To get a rough measurement of how off it was, I used a smart level I had, just to try and get a rough idea of what shims to order. This is the Passenger side and as you can see is about 1 degree positive. Factory spec is supposed to be 0 degrees. LOOK IN POST 7 FOR MISSING PICS
![1.jpg 1.jpg](https://www.steelsoldiers.com/data/attachments/294/294801-cc51e25b8c2f46985da9bdf2ae8bff1c.jpg)
![2.jpg 2.jpg](https://www.steelsoldiers.com/data/attachments/294/294802-65942cb5f772d031ea7b36625d310a6c.jpg)
![3.jpg 3.jpg](https://www.steelsoldiers.com/data/attachments/294/294803-806370a2046f018941b407588cbffa66.jpg)
First step is to remove the wheel, and take the caliper off
next remove the locking hub
Once you get the cover off you can start taking apart the actual locking hub assembly, remember how you take things apart, take pics if you have to.
![8.jpg 8.jpg](https://www.steelsoldiers.com/data/attachments/294/294809-47c0b28692f1bcb90f52ee726c41ecfd.jpg)
![9.jpg 9.jpg](https://www.steelsoldiers.com/data/attachments/294/294810-40ec432b91f790b3c4d5d90de71bef20.jpg)
![10.jpg 10.jpg](https://www.steelsoldiers.com/data/attachments/294/294811-452bb112a15e17042190fdb87f0c3889.jpg)
theres a hidden clip that fits in the outter hub
![12.jpg 12.jpg](https://www.steelsoldiers.com/data/attachments/294/294813-24e04139b223a6f2659e3ce990e64f7a.jpg)
then a c clip on the splined shaft
![11.jpg 11.jpg](https://www.steelsoldiers.com/data/attachments/294/294814-3c6e59b2fbfe1a122442b9822c8fdf96.jpg)
![13.jpg 13.jpg](https://www.steelsoldiers.com/data/attachments/294/294815-33924c69ff05232b6127c52c4c151743.jpg)
After you remove all the clips you can remove the basket
![11.1.jpg 11.1.jpg](https://www.steelsoldiers.com/data/attachments/294/294812-476bbac2e23a8e1b9134ace6b5a6c030.jpg)
