Failsafe Warning Control Module Plug Repair Help
juanprado
2,899
Metairie/La (N'awlins)
Where does wire 57 ground to the frame? Can you take a pic? What was the problem- loose wire, bad connection, rust?
Thanks for the insight!
Artisan
227
CDA Idaho
Both the Low Air Warning SWITCHES are close to each other on the passenger side. From the bottom switch follow the wire to the frame, maybe 7" long wire. I can only tell you what I did and grounding the cab to frame and the bed to frame and pulling 6-7 other grounds on the truck and cleaning all connections w/ a glass bead blaster and or other means I redid all gorund connections and now things work "As Advertised "
