VULCANGUNNER
- 1
- 0
- Clay Center, KS
Hello.
I have two M931 (A-zero) 5-ton trucks that I bought last summer from Red River Army Depot.
Everything on the trucks was good to go EXCEPT some bastard had taken a hammer & busted off the air hose fitting that connects the air dryer to the first (wet?) air tank. Neither truck was making air pressure but I could hear the compressor running so I traced the air lines back & found the busted air dryer outlet fittings. You could tell the fittings had been deliberately busted off to disable the trucks, just one clean strike mark in the same spot on both truck's fittings, not a rough grind mark like it had been hit while driving, etc.
Some turd at GL's site office probably has a brother-in-law Jethro with a wrecker service & they make a pretty penny towing out SABOTAGED 5-ton trucks with broken air lines for out-of-town suckers there to pick up their trucks. BEWARE OF SABOTAGED AIR LINES WHEN PICKING UP 5-TONS FROM RED RIVER ARMY DEPOT !!
Having been an M163 Vulcan driver/gunner for 3 years active Army (1st ID) & having worked on M939 series trucks for about a year with LSI at Fort Riley I know how to make an old Army vehicle run in a less-than-ideal parts situation. I removed one of the curly trailer air lines just after the ball valve shutoff & installed it between the air dryer & first air tank. It was far from pretty but they made air pressure so they could be driven off post. I looped the extra length of trailer air line over the front mud flap (red hose shown in first pic) to keep it out of the way & off we went! Trucks ran great during the 90 miles we drove them to my storage area, everything worked per manual specs.
I need to know where I can get the entire air dryer to air tank hose assembly, or at least the part numbers of the fittings & hose I will need to assemble my own replacements.
The old air hoses are beat up so I figured I would just replace the entire hose assembly. I have gone through the 3rd shop manual but can't figure out the part numbers for the parts I need. Many of those fittings are the same but they all have different part numbers in the manual.
The actual plastic air hoses are about 2 feet long & the broken part is the 90-degree fitting that screws into the air dryer outlet.
Any help you guys can provide would be greatly appreciated.
