Xtreme 4X4 Deuce bobbed(Spike TV)
m16ty
218
Dickson,TN
I don't know what ever happened to the old military firetruck they bought out of a salvage yard, as I never saw them touch it. We did see it parked in one epsode behind some other truck, hidden in the background. End of story??
The firetruck is the same truck in the show. I got the firebed from it.
The truck has been sold and like is said above, it's for sale right now.
13thArmy
Copenhagen
Thanks for the link Mike. Unfortunatly I can not watch the last episode here in Europe. Sure was fun watching the first 2 vides though!:)
Section8
Little Fort, B.C., Canada
I can't seem to be able to watch the clips. Waaaa! I have been wanting to watch them for so long.
Hey Ian! If your still checking this thread, come and get mine!! A 1956 M135. I am hoping to put a cummins 12v in it and make it a four door with disc brakes. And chop the top 4 to 6 inches.
Any way does any one know if it is on youtube?? I can't find the clips and powerblocks site doesn't seem to have it any more. I keep getting and error message.
Bobert
9
Des Moines/ Iowa
Just spotted this truck in Grand Island, Nebraska with Nebraska plates. Looked like it might have been broken down. It was parked off to the side at Walmart. Looks cool in person.
jsthnt@gmail.com
Grand Island, NE
It wasn't broke per say. I changed the timing to the to the turbo setting and was taking it for a trial run. That is just the spot that I always park when I go to Wally world. What Brought you to Grand Island, Ne.? The timing adjustment did not help as I had hoped or I just might have not done it right. General Granite is really doggy after I adjusted the timing. I hope it is because it was so cold today and I have all sorts of black gold in the tank. I wish I had been out side when you were there. I always like talking to other steel soldiers, there just isn't enough of them in central Nebraska.
FASTNOVA
146
Los Angeles,Ca
How is the that suspension holding up? any complaints? How many miles have you put on it? Very cool truck. Glad it went to a member here.
jsthnt@gmail.com
Grand Island, NE
The suspension is holding up fine. The compressors did not have a big enough holding tank to lift the truck with a load, so I removed the compressors an added that tank to the tanks that the truck came with. I also removed the electric ride height adjustment as the self levelers were not hooked up and eventual that caused problems. So I used a manual shut off. The only real problem that I have had is the bolts on the axles tend to loosen up. I will have to look at the gps to see about how many miles I have put on it.
m16ty
218
Dickson,TN
I always wondered why they went to the trouble and expense of adding the air ride compressor when the truck already had a factory air compressor.
Mike929
22
DFW, Tx
They added so the new equipment wouldn't use the brake systems and cause an addional load on that system. Would hate to lose you brakes due to an issue with the new systems.
They explained this in the show to answer questions posed by this group.
jsthnt@gmail.com
Grand Island, NE
The ball joints seem to be holding up fine. I do not think that I am taxing the old system any more than when you dump the air when you are done driving for the day. I have a manual lever behind the seat that I use to inflate and deflate the bags. The only real difference is that now my brakes have more air to use.
Bobert
9
Des Moines/ Iowa
It wasn't broke per say. I changed the timing to the to the turbo setting and was taking it for a trial run. That is just the spot that I always park when I go to Wally world. What Brought you to Grand Island, Ne.? The timing adjustment did not help as I had hoped or I just might have not done it right. General Granite is really doggy after I adjusted the timing. I hope it is because it was so cold and I have all sorts of black gold in the tank. I wish I had been out side when you were there. I always like talking to other steel soldiers, there just isn't enough of them in central Nebrascamp /QUOTE]
We were in town for the zombie 3 gun event. I saw something camo across the parking lot and had to check it out. We recognized it right away.
Glad to see it still on the road. We might bring something camo out next year.
swbradley1
Modertator
1,759
Dayton, OH
That and when the sponsors donate something they like to see it installed.
