2013 VIN INFO Thread
junker42
Pacific City / Oregon
Hi I hope you can help id my vin.
1990 BMY 923A2
#'s off frame next to steering box not sure which one is serial #
019094342
12256104A
NSN 2320012300307
Joint Base Lewis Mc Cord
Need to find # for title vin
Thanks
CARNAC
The Envelope Please.
619
Corpus Christi, TX
M923A1
S/N C52301979
Reg# NL0CCL
NSN# 2320012064087
Picked up in Indianapolis
Bumper #'s IL ARNG 1844TH TC 211
Thank you sir in advance. Eric
Organization:
0221
221ST ORDNANCE COMPANY
FORT WAYNE
IN
Unit Ident Code:
WQ34AA
Utilization Code:
A
Vehicle Use Code:
Nomenclature:
TRUCK CARGO D/S 5-TON
Model:
M923
NSN:
2320010502084
Serial Number:
C52301973
Registration Number:
NL0CCL
Year of Mfg:
1983
Manufacturer:
65909
Contract Number:
DAAE07-81-C-5597
The serial number didn't take so I used the registration number. Not sure what the issue was. Info is from Mar 1995
CARNAC
619
Corpus Christi, TX
1990 BMY 923A2
019094342
12256104A
NSN 2320012300307
Thanks
No info. The serial numbers don't look right.
CARNAC
619
Corpus Christi, TX
1966 M275A2 W/W.
NSN # 23200771641
Serial number 4J8533 (on data plate and painted on inner door panels ).
Was a Yakima Indian nation truck that was sold to an auto wrecker where I saved it from the torch !
Thank you in advance for all you do ! Donation on its way!
Info is Nov 1993. You game me the registration number not the serial number. You must validate the serial number shown below on the frame and ensure you title/register the truck using the serial number.
Organization:
USPFO ACTIVITY IDAHO ARMY NATIONAL GUARD
GOWEN FIELD
ID
Unit Ident Code:
W7M5AA
Utilization Code:
Vehicle Use Code:
Nomenclature:
TRUCK TRACTOR
Model:
M275A2 W/W
NSN:
2320000771641
Serial Number:
22410086
4J8533
Year of Mfg:
1966
CARNAC
619
Corpus Christi, TX
Hello CARNAC
I have two for you. Thanks a lot for doing this for all of us
#1
1967 M35A2 WOW
A: 022517694
B: 4L6712
C: 2320000771616
D: Purchased from GL, Picked up at Camp Dodge in IA
E: (Pass/Side) 34334 BSB (Driv/Side) A158
#2
1991 M923A2 WOW
A: 2307569
B: NL14XX
C: 2320012300307
D: Puchased from GL, Picked up at Ft. McCoy in WI
E: (Pass/Side Upper) 645th RSG (Pass/Side Lower) 406th CSSB (Driv/Side Upper) 952QM (Driv/Side Lower) QM453
Thanks Again
Organization:
952D QUARTERMASTER COMPANY
LIVONIA MI
Nomenclature:
Model:
M923A2
NSN:
2320012300307
Serial Number:
2307569
NL14XX
Year of Mfg:
1991
Manufacturer:
47457
Contract Number:
DAAE07-86-C-J111
June 1998
Organization:
COMPANY C 334TH SUPPORT BATTALION
JOHNSTON IA
Nomenclature:
TRUCK CARGO 2-1/2T
Model:
M35A2
NSN:
2320000771616
Serial Number:
22517694
4L6712
Year of Mfg:
1967
Sep 2004
CARNAC
619
Corpus Christi, TX
Carnac,
If possible, I would like some info on the M915A1 I just purchased.
A. 1UTSH6685DS001244
B. NP078K
C. 2320011252640
D. Nellis AFB, NV
E. ?
Thanks for your time.
Organization:
TASS TRAINING CENTER FT HUNTER LIGGETT
FT HUNTER LIGGETT
CA
Nomenclature:
TRK TRACTOR LINE HAUL
Model:
M915A1
NSN:
2320011252640
Serial Number:
1UTSH6685DS001244
NP078K
Year of Mfg:
1983
Manufacturer:
65909
Contract Number:
DAAE07-81-C-6205
Aug 2011 Info
CARNAC
619
Corpus Christi, TX
Here's one for you.
M931a1
a. s/n C53102582
b. Reg NL0LPU
c. NSN 2320012064077
d. I picked this truck up from Redstone but I have found evidence in the cab that it came from OK.
e. What I can read of the bumper number is 777AVN.
Sep 2004
Organization:
0658 TH QM CO PLT A2 SUBSISTE
TUPELO MS
Nomenclature:
TRUCK TRACTOR 5-TON
Model:
M931A1
NSN:
2320012064077
Serial Number:
C53102582
NL0LPJ
Year of Mfg:
1985
Manufacturer:
65909
Contract Number:
DAAE07-81-C-5597
CARNAC
619
Corpus Christi, TX
Thanks again for this service you provide.
M931a1
s/n - C53102328
NSN - 2320012064077
No other readable numbers.
Truck was picked up from GL in Indy, believe came from IL National Guard unit.
Organization:
900TH QUARTERMASTER CO
FT BLISS TX
Nomenclature:
TRUCK TRACTOR 5-TON
Model:
M931
NSN:
2320010478753
Serial Number:
C53102328
NL0LG2
Year of Mfg:
1985
Manufacturer:
65909
Contract Number:
DAAE07-81-C-5597
Apr 2007
CARNAC
619
Corpus Christi, TX
Greetings!
Truck, Cargo, 5T
M923A1
SN: C52308248
Reg Num: NL0KN3
NSN: 2320012064087
Mfg: AM General
Purchased at New Castle, DE
Thanks!
Organization:
351ST ORDNANCE COMPANY 3D PLT HEAVY LIFT
MORGANTOWN WV
Nomenclature:
Model:
M923A1
NSN:
2320012064087
Serial Number:
C52308248
NL0KN3
Year of Mfg:
1985
Manufacturer:
65909
Contract Number:
DAAE07-81-C-5597
Sep 2011
Heck I might have driven this truck when they first got it.
Gerry
Cheshire, Ct
Oh Great Carnac,
I posted but did not get a response. Does that mean its not Army?
1953 M37
80051867
Maine
"I have a M37. The only info I am sure of is the frame number 80051867. I bought this truck in Maine. Any info would be greatly appreciated.
Thanks and I will be glad to donate to your worthy cause."
Thanks,
Splash
Massachusetts
Wanted one bought 2 oops....
M931A2 WO/W 1990BMY-Div of Harsco
Serial no. 31701873
Note on serial no. gl listing says 3101873 but 31701873 is ondash plate.
NSN: 2320012300302
GL Richmond VA
Passenger side front bumper; 329RSG above 529CSSB
Also has MC45 on rear of cab
M931A1 WO/W AM General Corp (no year stamped)
Serial no. C53103006
USA no. 541126
NSN: 2320012064077
GL Mechanicsburg PA
Any info greatly appreciated .
svanhorn
loa, ut
Hopefully you can shed some light on this one. It is a M101, with a M101A1 data plate.
Serial: 5863
registration: ?
NSN: 2330008986779
Bought from: Private collection listed on GL, most likely came from Tooele Army Depot.
Bumper #: ?
Manufactured by case master, delivered 3-62, contract3: DAAE07-67-C-4183
If it helps, there was a small plate screwed to the frame with what appears to be an "I", then 8731210.
jimbocw
Bryan, TX
Carnac,
Thanks for you assistance. I am new to the military truck world and recently purchased two M923A2 truck and am not sure what to put on the SF97 form. Here are the numbers I got from each truck.
Truck #1:
BMY by Harsco
Numbers from Tag
M923A2
SN#2307064
USA# NL0R4B
NSN 2320012300307
Numbers on frame:
1129 94342
12256104A1G
Truck #2:
BMY by Harsco
Numbers from Tag
M923A2
SN#2302885
USA# NL0YWV
NSN 2320012300307
Numbers on frame:
0158 94342
2256104A1G
Thanks again,
Jim
Grits
Darien, Georgia
Carmac, Thanks in advance for your help. Clinto referred me to your thread, so it's his fault you're having to tolerate me.
I've had my M151-A2 for many years, but never "identified" it...
Nat'l Stock #.... 2320001779258
AM General
Contract # DAAE0779D5016
VIN # 520893D15103036
Thanks Again,
Grits
1 Patriot-of-many
72
Zimmerman MN
Hi Carnac, I just donated $30, Honestly I was remiss in not donating when you supplied info on my deuce.
Need some info on a M923 particularly the year manufactured if you have it.
Serial # C52306497
NLOHXB
NSN# 23200010502084
Camp Ripley, Little Falls, MN
Left side markings front: 84 851 E Right side markings front: V3121
Thanks for your help.
CARNAC
619
Corpus Christi, TX
1990 BMY M923A2
serial #2303616
registration # NL0Z2U23
NSN2320012300307
Thanks for the info and your time.
Info Sep 2012
Organization:
USPFO TRANS ACTIVITY
SALEM
OR
Nomenclature:
Model:
M923A2
NSN:
2320012300307
Serial Number:
2303616
NL0Z2U
Year of Mfg:
1990
Manufacturer:
47457
Contract Number:
DAAE07-86-C-J111
CARNAC
619
Corpus Christi, TX
Oh Great Carnac,
1953 M37
80051867
Maine
Thanks,
No NSN. Read post numer 1.
CARNAC
619
Corpus Christi, TX
Serial no. 31701873
NSN: 2320012300302
GL Richmond VA
USA no. 541126
NSN: 2320012064077
GL Mechanicsburg PA
Validate the serial number via the frame before posting. Read post 1.
