shannondeese
- 16
- 18
- High Springs Fl
I have gone through the trouble shooting steps so many times I can't see straight anymore. So I'm here to ask for some help. I have a Deuce that has a charging issue. I am getting 23 VDC at the exciter wire. 23VDC at the batteries. But 0 VDC at the alternator out put terminal. I have changed to a known good alternator and still have the same problem. The trouble shooting manual says to now change wire 2. Which is fine if I knew where wire 2 goes. It disappears into the wiring harness right under the alternator. Any and all help would be appreciated. Thanks.
