1968 M35a2 non turbo
I read here about how to turn up the fuel on the injection pump. I noticed on my truck that someone has already maxed it out. The only thing is that my truck doesnt smoke at all. Does this mean that my injection pump is worn out and its not supplying enough fuel? It runs fine but In 5th gear is slows down alot while going over hills, I would like to get just a hair more power out of it if possible. Not sure if this matters but the guy who owned it before me must of been running used motor oil because all the filters were clogged and gas tank was black. I just put in a new fuel pump and all new filters a month ago and been running straight diesel. I have ran the truck through about 3 full tanks since then., and just wondering if the used motor oil may have damaged the injection pump? I dont usually work on diesels so Im somewhat lost if this is normal or if I need to rebuild the IP.
