Are you kidding me? Squealling coming from generator
cllctrtom
Altoona, PA
A few months ago, I started to get a high pitch squeal from my generator. The squeal would go away when the accessory switch was turned off but of course the vehicle wasn't charging. I replaced the generator the other day and low and behold after about 10 min. of running it started to do the same thing! What is going on and why does it do this?
Can someone shed some light?
Thanks in advance!
1,132
How tight is the belt?
EWhytsell
Fort Mill, SC
When the switch is on there is a load placed on the generator. Switch off and its free wheeling so no belt squeaks and no other noises. Some noticable noise should come from it when its under load, but it shouldn't be noticed standing outside the truck with all the other vibrations/noises.
1,132
Bingo!
I've always done it by feel (i.e. how tight to make the belt) but there is actually a tool to measure belt tension. Of course, you'd have to know what the spec is for the tension for this to help.........
http://buy.snapon.com/catalog/item....675585&supersede=&store=snapon-store&tool=all
cllctrtom
Altoona, PA
The noise is unbearable. You can't be anywhere near the truck and the sad thing is we use it in parades. Why is it squealing?
1,132
So if it is the belts, how tight should they be?
This is gonna' sound smart alecky, but tight enough for it not to squeal and loose enough not to burn up alternator bearings.
Also, those belts are designed to be a matched pair, meaning both belts cut from the same piece. So they are both identical to one another. Ask your parts house for a matched set, they'll know what you mean. I'd replace em if one is longer than the other.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
This is gonna' sound smart alecky, but the only load with the switch on is the batterys. Then if he turns on lights and stuff, there is more load. :)
What condition is your batterys in? Do you have the right sized belts? I had some that would not tighten up when my adjuster was ALL the way out. Turns out the belts were too long.
cllctrtom
Altoona, PA
To be honest, I would have bet a hundred bucks it wasn't the belts but what you, (and others) are saying makes sense. I will get a matching set of belts and get them tightened properly and see where that takes me.
In short, I wasted my time changing generators?
1,132
This is gonna' sound smart alecky, but if the belts have been slipping, the batteries may not be fully charged, which means the alternator is under a heavier load trying to recharge them. :)
Don't know.
Did you, before swapping:
A. Put a multimeter on it and check the output
B. Check the bearings to see if the pulley turned smoothly
gimpyrobb
27,786
755
Cincy Ohio
Yes, but the switch doesn't create the load, the switch just turns on the charging circuit.
cllctrtom
Altoona, PA
Batteries are less than a year old. Not sure if the belts are the right size. I can only assume.
You guys answers are great and I appreciate everyone's help!
I spent 20 years in the military and can operate anything from a M48 to M1 series tank but can't figure this **** squeal thing out! Go figure.
cllctrtom
Altoona, PA
Don't know.
A. Didn't check voltage
B. Generator spun fine. In fact a little better than the new one.
1,132
Ok, all joking aside now..........
Isn't the activation of the charging circuit what creates the load? I.e master power switch is off, belt is simply turning the reciprocating mass of the alternator. Switch on, alternator "sees" battery voltage and attempts to charge, alternator sees load, belts squeal, tom posts, etc.?
gimpyrobb
27,786
755
Cincy Ohio
I would look very close at the belts. It wouldn't surprise me if they have been glazed over too. The correct numbers escape me right now, I'm at work(farting around on company time!).
