Anybody, that knows a Deuce (or equipment in general), just a little, will have the truck running in minutes with a nail or screwdriver. My thinking was to install a battery switch, but hide it. Mine is located near the starter (it only took about a foot of extra cable), and it interups battery power to the starter. I can reach it from under the wheel well, there by the exhaust pipe. Its out of sight. By switching it off, the truck won't start, even though you have the impression that things should work when you push the start button, and the Accessory switch, has everything else on. That will puzzel a few, but not some! If they are smart, and lift the hood, the game is over.\
Along with the above, is a buiness size card taped to the corner inside the drivers side window, stating that if they are close enough, to read the card ("fine print"), they are too close to the truck. Go on to briefly state, SOP and what "really" will happen if you catch them!
