Hooper
- 0
- 0
- Grand Rapids
I was combing through the TM's when I found the touble shooting catergory that says surging idle. Which is what I have. All it says is that if the it can not be adjusted with a cable adjustment to contact DS maintenance. I was in the middle of adjusting the kick down cable when I disconected the throttle cable. This truck has always had a hunting idle that I figured was dirty injectors. With the throttle cable disconected the idle was all over the place. When the throttle is increased by hand and then quickly moved down, the idle stays up for 1-2 seconds by itself. Any ideas?
