ctappan94
- 0
- 0
- Jersey Shore
the copper piece is big enough to go around the inner diameter, but the threads are simply too large. .. any ideas?
It was too tight to remove so i had to cut it. Is there a secret way to put these things on?What happened to the copper gasket that was installed with the plug prior to you removing it? These gasket are re-useable if their not mashed, overtightened.
To simpleuse a file?
File? A hanging one with the hooks? Or can you use the plain kind.Use a file?
