Bump Cap
oifvet
9
(near) Xenia, Ohio
I've banged my head against things a few times and always learned from it. My dad always said, "If you hit someone in the head, they always get smarter. You either knocked something in, or knocked something out. Either way, they're better off."
That said, I ordered a few baseball-cap style bump cap inserts. They fit nicely inside just about any baseball-style cap and serve a good purpose. I no longer worry about creasing my scalp on the door-frame of my M35A2 when I step up into the cab. They come in handy underneath the truck, as well.
Example:
http://www.supplylinedirect.com/new...s-head-protection-a-whole-new-look-and-feel-/
doghead
4 Star General /Moderator
1,176
Great idea, have any pics or order info?
4,744
How do they wear? Seems like it wouldn't be something I'd want to wear in the middle of summer? (Heat)
SteveKuhn
Hasbrouck Heights NJ
It looks like a lot better idea than the batter's helmet I use - and batting is for summer. Vents are good and the foam inserts probably allow for circulation. Coulda' used it yesterday working under my trailer. Darned landing leg . . .
Steve
wheelspinner
1,518
North Carolina - FINALLY !
If they are like the ones we used in the airplane hangers, you really don't notice as they are very thin.
I must be missing something on the pricing, coming up at 20+ each??
USAFSS-ColdWarrior
Chaplain
5,763
What timing!
One of the local Florist's delivery guys just dropped some arrangements off here at the Funeral Home and was showing me the fresh wounds on his head... They just got a new delivery van and the door is just a bit lower (or maybe the threshold/header orientation) is just an inch or so different and he nailed his scalp on the header SEVERAL times yesterday.
So.... I just shared this VALUABLE information with him.
He said to thank YOU for giving him this info before he inflicts permanent damage upon himself.
oifvet
9
(near) Xenia, Ohio
I would say, not bad. There is a strip of padding inside, along the top that keeps a gap for air circulation, and there are a few vent holes. I just keep it in the seat to remind me to don it before entry. I have mine inside a camouflage "Reds" cap. It is not heavy and I don't "sweat" the heat.
Here is where I got mine (4). They fit in either the low-profile baseball caps, or the taller "dad" style caps. Thick enough and padded enough to make you say, "Whooo! That would've hurt!"
http://www.esafetysupplies.com/CAP-INSERT-WITH-FOAM-PAD.html?gclid=CJ7R3pCUx7gCFa87MgodqSIABQ
John S-B
1,020
Ostrander, Ohio
I kind of like the helmets used for rafting, they cover the back of your head and have a chin strap so it doesn't come off easily. And if you're working on something too low or rough for a creeper, you won't have to hold the back of your head off of the ground as you move around on your back, your helmet protects and supports your head.
