l.l.lind
- 0
- 0
- Cambria, WI
Does anyone know what percentage of deuce's that were sold thru Government Liquidation had DOT 5 brake fluid vs DOT 3? I'm in the early stages of replacing all 6 wheel cylinders and the master cylinder on one of my M35's because of brake failure, and tried to use a syringe to extract brake fluid from the master cylinder to test it, but the master cylinder was empty. The only clue I found was a drop of fluid on the bottom of the cap on the master cylinder. It was a greenish yellow fluid, almost iridescent. There wasn't enough to test by mixing in water.
