Very Modified Deuce
Tornadogt
Adkins, Texas
Multi-Fuel put to good use... wouldn't be cool to see him pull up to a oil change place suck some Waste Oil into the fuel tank and keep on trucking....
Who said you can't get 20 mpg from a Deuce multi-fuel?
wreckerman893
Possum Connoisseur
15,629
2,051
Soooooo......is that a "Little Deuce Coupe"?
Looks like it would be faster than a deuce, but I'm skeptical about the front suspension handling the weight for very long.
That radiator looks pretty small for the Multi. It would have sounded a lot better with a whistler turbo on it. It does have a lot of character and I do have a couple of Multi's out in a trailer. Like I need another project.
215Dave
Northeast Phila, PA
That leaf spring stack in the front is interesting. Is that mostly to help support the engine and/or dampen the front end?
Yes, that leaf pack does both. In the hot rod world, that set up is referred to as a "suicide spring". If that we're to snap off....the front end digs in at speed......well, catapult! :cry:
