Mountainwolf
- 0
- 0
- Post Falls ID
My friend that is an OUTSTANDING job, the way it is supposed to be done!
Thanks, I used a sawzall with metal cutting blades, took a cutoff wheel to start the hole in the bed. I used a cutting torch to cut the bed off the subframe.Nice looking job, what did you use to cut the bed?
I used the measurments off the XM381 site, and added 3 more inches so my axle will probably be 8 inch further back.looks really good!! I didn't see if you mentioned it or not but did you keep the center rear axle position to same or did you move it?
