kwest
- 0
- 6
- Camp Verde Arizona
Hey Gentlemen: I am kinda new to this forum and I have read posts dating back to 2009 trying to learn everything I can about my MEP-004A. The problem is I can't get it to flash the field to get voltage on the Hertz and the volt meter. I have held the stop-run-start switch for 30 seconds without any luck. I have ran the engine at full throtle since I bought it just to keep it from siezing up. It will flash occasionally and make the meters measure volts and 60 cycles on the hertz. Up until just the other day it ran without the re-connection board because it was missing when I got it. It is running @ 1866 RPM and the alternator is now putting out about 28v's. Any help will be welcome for a retired Lineman who for 35yrs said one wire hook up two wire screw up....I hope that I have covered all the info that is needed for a response . I thank you in advance for your input
