fredster67a
- 0
- 6
- College Park, MD
M1008 Lift Kits - Seek advice on size ( 2,4,6 inch) & type: block or reverse shackle
Hi, Thinking of retrofitting my M1008 with a suspension lift kit so that I can install Goodyear Wrangler 37 X 12.50 M + S tires ( came off a Humvee) and not have to do any modifcations to the fenders. I have run into a couple of different schools of thought regarding the rear lift - one is that no block larger than 2" is desirable since this will subject the vehicle to rear axle wrap - this kit uses a reverse shackle set up - the other school of thought is that a rear block up to 6 " thick is fine - and you will not have to worry about axle wrap. Just wondering if anyone has tackled this type of project and what method you used for the rear lift as well as what size lift you think is needed in order to mount the Humvee tire and not have to do any fender or bed modifications. Thanks in advance for your advice. Lastly any recommendations on good places to go to talk to knowledgeable folks about this is always a bonus - thanks agin.
