I've had a persistent and increasingly annoying problem with my CUCV snapping the Grade 8 Starter Bolts about every 2 months of daily driving. At first I think it was because the last shop that replaced my starter didn't use shims and it got loose somehow.
I've had to replace the starter bolts about 3 times now in the last 6 months. Each time the bolts are breaking off just below the threads, leaving the threads inside the block. The last time it happened it actually stripped the threads out of the block and I had to drill out the hole, tap it, and I used a Heli-Coil, which I assumed was holding well enough.
I haven't had a chance to look in the hole yet to see if the Heli-Coil is still there and in good shape, but I'm really wondering what is causing this to continue to be an issue. The starter was properly shimmed, correct Grade 8 bolts from O'Reilly's, and the support bracket was in place and tight. I don't get it.
