- 2,074
- 873
- UT
My truck's Airpack (new, short-style) had an issue several months ago with the air-slave cylinder, where it caused brake pressure to be applied while driving and the brakes were dragging. I removed the Airpack and rebuilt it with a kit from TNJ Murray. I took photos as I went along and I thought that I had everything reinstalled correctly; no instructions were included and I can't find any info anywhere on the rebuild procedures for the new-style Airpack...all the photos & instructions via MV Magazine are all related to the old-style Airpack.
Upon reinstallation, the truck wouldn't build air pressure at all. I sprayed soapy water everywhere with no luck. When shutting down the engine, I could hear a brief (3-5 seconds) of what sounded like air leaking down behind the dash cluster. I removed this and fired up the engine to try to build up air pressure to see where it might be coming from; no luck. I checked all these air fittings behind the dash, but nothing was kinked/leaking. Hmm.
I replaced the air governor (NAPA unit, $11); still no air pressure. I took the head of the air compressor apart & cleaned the gunk out of the valves, lubed up the O-ring on the unloader valve, and reinstalled everything. Still no air pressure. Finally I hooked up an air hose to the emergency gladhand and pressurized the air system, and air immediately poured out of the vent for the Airpack; the system wouldn't pressurize and all the air went immediately out of the Airpack vent line (the one that terminates above the engine air cleaner in the engine compartment).
I've searched for several days using various search terms throughout the Deuce & Deuce Mods sections without luck...a few posts came up where members had similar symptoms as I am having, but involved the old-style Airpack. I've looked through all of the TMs I could find online, but none show how to disassemble/service the newer-style short Airpack...I've even searched through the T-Pub site and a couple of other DOD sites, but no luck.
I can't find any instructions nor photos of the new style (short) Airpack being rebuilt...does anyone have any they can share? Did I install something wrong? The air pressure is going straight through the slave cylinder on the Airpack and out of the vent...it won't build pressure at all. What the heck did I do?
Thanks in advance for any help...maybe this will get some photos & instructions for the mysterious short Airpack finally posted.
