hogpatch
- 0
- 0
- Epps, Louisiana
I bought my oo3 1 week ago. I've been reading your posts trying to learn enough to check it out & maybe ask sensible questions. It runs great, But no output. The DC generator under flywheel checks good except when you check across both leads while running, only 27 or 28 volts ( I'm thinking I may need to pull flywheel & clean it). The capacitor at the bottom of the regulator(rectifier) has wire broken( I need the best place to find it) I flashed the generator while revved & Hertz meter & volt meter came right up to 62 hertz & 118 volts. Soon as I stop flashing it drops immediately ( I'm thinking one or more of the 6 rotating diodes are bad? If so, where to find them & are they cheap enough to just replace them all?) Also, on the A-4 board, cr2 & cr5 diodes look to be burned. Are they in the exciter circuit & can they be replaced on board without having to re-place the whole board. I also checked & cleaned the frame ground.( It was ok as this machine doesn't seem to have any corrosion problems) It is on covered trailer. Should there be any spark when connecting battery cables after they have been disconnected? I would like to make a list & order all parts needed soon. I would appreciate any help I can get .
